Thread Tools
Old 28-10-2013   #1
Fiat Panda 1.1 (0.5) active heater works intermittantly
Hi Guys/Girls,
My heater has stopped working. The fan seems to work just no heat. This happened last week for one journey, and the next drive all was fine again
Today I had a cold one hour journey to work so not sure if the return trip will be warmer
All the fluid levels seem normal - coolant, oil but last week the engine overheated in heavy traffic. I had a red temperature light indicating for a few mins until I resumed traveling and then it went off again.
Do you think this will be expensive to fix?
tabuk is offline Reply With Quote Quote
Old 28-10-2013   #2
varesecrazy has donated!
Re: Fiat Panda 1.1 (0.5) active heater works intermittantly
you've almost certainly got an air lock problem,
any idea when the coolant was last changed / disturbed ?,
if not ,
probably a good idea to dump it for fresh and bleed again,
EDIT = are you SURE the coolant is near the MAX mark??,
easiest to check with a torch illuminating the wall of the rad's filler tube,
plenty of GUIDE pictures on bleeding the panda and similar punto, where are you based..??
Charlie - 1.1 active owner - Oxford
Old 28-10-2013   #3
Trader Rating: 5
fingers99 has donated!
Air lock is probable, bleed with heater set at full heat.
It's just possible the head gasket has gone -- compression test advised.
Overheating at a standstill may also indicate that the radiator fan isn't working.
Anyway, best posted in the Panda section.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 19-11-2013   #4
Hi
Same thing has just happened to my Panda, 3 years old! Not a good time to be driving 15 miles to work with no heater! Just wondered if you got yours fixed, what the problem was...and how much was it??
Thanks!
Starry15 is offline Reply With Quote Quote
Thread Tools
(T) 1-3 Heater not working 4 works bethwills Grande Punto 7 14-04-2016 11:45
Heater only works on number 4 :( Ads82 Newbie Central 0 26-03-2012 20:43
(T) Heater is weird how it works mitseymoo Punto (Mk2/2b) 6 03-01-2010 19:23
(G) fiat punto, no wipers and heater only works on full batbeanz Punto (Mk2/2b) 2 24-01-2006 23:24
