Thread Tools
Old 16-06-2012   #1
punto 1.9 jtd not starting! PLS Help
i have a w reg 2000 fiat punto and is not starting i can`t find any reasons not to!
i tested the ecu and all i got is p0236
Boost Pressure sensor A circuit range/performance
The reason for this fault is that ECU has received invalid signal from the sensor. The fault is not detected now. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
any ideas welcome!
johncop is offline Reply With Quote Quote
Old 16-06-2012   #2
Re: punto 1.9 jtd not starting! PLS Help
What happens when you try and start it?, does it turn over? If it does is it slow or quick.
How old is the car? Has it had things like a new cambelt at the moment it's impossible to tell anything from what you've said as the fault you found wouldn't stop the car starting its simple coincidental
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 16-06-2012   #3
Quote Originally Posted by AndyRKett View Post
it dose turn over quick! the car is 12 years old, i have`nt changed anything new at the car ... it just stoped working for no reason!
Old 16-06-2012   #4
if it turns over much faster than it normally would when starting, its a good indicator that the cambelt has snapped.
but thats not a definitive answer. you'd need to investigate further
Thread Tools
(T) Punto JTD Starting Problems tims31 Punto (Mk2/2b) 2 31-01-2012 00:42
(T) fiat punto n Reg. starting problem pls reply urgent silkambu Punto (Mk1) 0 31-03-2009 15:00
