i have a w reg 2000 fiat punto and is not starting i can`t find any reasons not to!
i tested the ecu and all i got is p0236
Boost Pressure sensor A circuit range/performance
The reason for this fault is that ECU has received invalid signal from the sensor. The fault is not detected now. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
any ideas welcome!
any ideas welcome!
