Fiat idea running gear?
andyhot
Hi everyone.
I am trying to find out what platform the fiat idea is based on as i need a new front stub axle/ hub flange(unsure of proper name). as i have replaced a worn bearing and the hub flange has worn so its a loose fit and just slides inside the bearings inner race. i can't find one for the idea but have seen them for other fiat models. so i was just wondering what cars share parts with the idea. Thanks in advance Andy.
I believe Idea is Mk2 Punto in bigger frock.
Check-out ePER (on above drk/blue bar).
Look for axle & axle shafts - exploded views & P/No's on there.
Check ePER for Idea & Punto Mk2(188) as well for common parts.
Commonality probably wider than that.
120112
120112
Thank you very much i will have a look. :)
