You need to know the ET of the wheels first. And that the bigger the ET, the closer the wheel sits to the centre line of the car. So, if the ET of the new wheels is bigger, you use spacers to make up the difference. If the ET is smaller, you're pretty much screwed.
The safe way to do it is to use the ET of the old wheels as a gold standard to stick to -- this prevents horrible geometry changes which can, at the extreme, have you in a ditch in the blink of an eye.
Another way is to buy a stack of washers and use these to pad the wheels out until it all fits. You absolutely must not run the car in this condition, it's for measuring only.
Please don't use nasty "universal" spacers, get decent ones with the right PCD and counter bore, hubcentrics if over 10mm.
A stud conversion will be a better idea than longer bolts, especially with wheels that big unless you have majic muscles.
Multiplas do look good with bigger wheels and tyres.
