do it yourself spanner, rubber tube with end blocked and lil slit in at the bottom (can buy from halfrauds iirc) and a friend to pump brake and top up fluid. Really isnt a hard job so may as well do it yourself
edit: you need a small bottle too with a little fluid in it. i use an old disposable soap dispenser bottle
yes i know but doing the engine conversion slightly wrong wont risk my life
ide probably do it mywself anyway but i dont really have the time anyway.. that and i dont trust myself just incase.
i know theres air in the system as i fitted a new rear arm without bleeding the system after. seemed fine till now when ive just put on dome new pads and disks (fancy ones heh) and had to compress the front bit and now the pedal sinks alot further than it used to so i dont really wanna risk doing high speeds till its back to normal
i got the thing bink talks about from wilco (car place not wilkinsons) for £10 you just screw it to top of brake fluid tank, then go around letting fluid out of each nipple, it comes with full instructions, and you can change all the brake fluid in 10 minuets with it,
Just be sure that the brake nipples ain't seized. If they look like they aint gonna budge take it to garage and let them break it. I snapped one of front ones and had to buy another caliper. IIRC its a 8mm spanner to undo em. The one i sheared had rusted so much that a 6mm was loose on it
If the rears look crappy then buy new cylinders. £3 each from NeedforSpeed
