Set time (Setting the clock)This function enables to set the clock
through two sub-menus: “Time” and
“Mode”.
Proceed as follows:
– briefly press buttonMODE, the display
will show the two submenus “Time” and
“Mode”;
– press button (UP) or (DOWN) to scroll the two
submenus;
– select the required submenu and then
press briefly MODE;
– if selecting “Time”: briefly press button
MODE, “hours” will flash on the display;
– press button (UP) or (DOWN) for setting;
– press button MODE, “minutes” will
– press button (UP) or (DOWN) for setting.
Note: Every press on button (UP) or (DOWN) increases/
decreases by 1 unit. Keeping the
button pressed obtains automatic fast increase
or decrease. When you are near
the required setting complete adjustment
by single presses.
– if selecting “Mode”: briefly press button
MODE, “24h” or “12h mode will
– press button (UP) or (DOWN) to select “24h” or
“12h”.
After setting, briefly press button MODE
to go back to the submenu screen or
press the button for long to go back to the
main menu screen without storing settings.
– press again button MODE for long to
go back to the standard screen or to the
main menu according to the current menu
level.
you don't use the steering whell to change the time (well not in my 2007 1.4 T120 Dynamic).
In the central part of the dash are 3 buttons with the central one called mode, and the others pointing up and down - these buttons are normally used to adjust the headlights - use them
Here are the instructions from the handbook:
“Mode”.
Proceed as follows:
– briefly press button MODE, the display
“Mode”;
– press up or down button to scroll the two
submenus;
press briefly MODE;
– press button up or down for setting;
– press button up or down for setting.
Trev
Damn it..
Dom
