Spark Plugs and Spark leads
Sando
Established member
Chesterfield, United Kingdom.
What Spark Plugs and Spark leads does everyone use? I want to get some but I dont know which are best, how to fit them and which ones work with Cinq Sportings?
Can you help??:)
Fitting them is easy, you pull the HT lead off it and use a spark plug socket to undo them.
When fitting them back in do them up with your fingers first be careful not to cross thread them, up to the point where you can't tighten them with your fingers no more then gently tighten them up a bit using the socket BUT not to much other wise it'll snap then your in big trouble!
Pete will know which ones to use, he knows everything :)
My Car is now for sale, A total one-off, head turning bargin!!!​
I've seen the Bosch ones in Halfrauds and going to get a set tonight but what sort do I get? There was lots of different numbered ones, anyone know for a Sporting?
Look at the application list on the shelf. Last week, Halfords had a special offer on Bosch plugs, super 4's for £15.
The Bosch Super 4's make centos run a little smoother, I'd recommend them. No plug is going to give you a power boost though, unless your old ones are really bad.
For plug leads, Magnecor are supposed to be the best, about £40 a set.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HINT: Replace the leads one at a time to avoid messing up the firing order.
_________________________
2003 Stilo 1.6 Dynamic 3dr, Orion Grey, 17" Alloys, Dual Zone Climate Control, Aluminum Sills, Clarion DXZ928R, Kenwood DualMags, Clarion SRX1784, de-badged.
I accept no responsibility for anything contained in my posts, or any decisions you make based on them.[^]
