Hi all
I have an annoying issue with my Stilo 1.9 JTD 115.
If the weather is cold (below 0 c) the car is extreme difficult to start. The lower the temperature gets, the lower the chances are that it would start at all.
As soon as the temp raises above 0 (ie 3 degrees) the engine starts in first attempt.
I got a occasional warning in the instrument panel saying I got water in the fuel filter, but that has been there almost since I got the car and is only lasting a few seconds.
The garage has checked the following:
Water/sediments in the tank
Pump
The injection system
Preheater
Changed the fuel filter (see above desription of warning)
And found no errors. The only fault they got was from some kind of pressure gauge, which they cleaned and that seemed to help for a short time.
Now the problems has re-ocurred and it feels like it has gotten worse.
The garage want to change the gauge, as it seems to be the only clue they have on this issue.
On the opposite side, I have started to wonder if there are some kind of device that checks the air-temp, and controls some startup parameters based on this...And if it could be this part that is failing.
BTW: I still got the warning about water in the fuel filter, it reocurred the same day they had changed the filter.
Is there any Stilo masterminds out there that has any idea of what could be wrong??
I don't want the garage (authorized dealer by the way) to change the whole engine because they are clueless.
Best regards
Carsten
Pump
Preheater
Best regards
Carsten
