Old 07-03-2005   #1
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: 1
JonnyBoy has donated!
Fitting a Punto 60 throttle body
I've put this in "lets talk Fiat" as I reckon more Cinq 1108cc owners will have done this than Punto owners.
I've just bought a Punto 60 throttle body off ebay (looks like new, done 30000 miles and is 32 quid delivered ). 2 reasons for this: (a) I suspect that my Punto 55's rich running and crappy economy is down to a shot throttle potentiometer, and (b) the 60 TB is supposed to give a bit more power on the 1108 motor
What I want to know is, how hard are they to fit? Obviously gonna be a bit of a cow what with all the wires and pipes and things, but is there any trick to it, like depressurising fuel lines, removing air locks, etc etc?
Past: '91 Uno 45 Formula; '94 Punto 55SX; '58 Bravo 1.9 Multijet (150BHP) Dynamic, with extra toys
Present: Several, but nowt Italian...
JonnyBoy is offline Reply With Quote Quote
Old 07-03-2005   #2
Winning
GhostWKD's Avatar
GhostWKD has donated!
Re: Fitting a Punto 60 throttle body
when i did engine swap i didnt depressurise anything, just yanked pipes off (expect bit of petrol to come out of the petrol pipe though )
GhostWKD is offline Reply With Quote Quote
Old 07-03-2005   #3
Chris
Trader Rating: 2
Bushboy has donated!
i did the same... just took the pipes off... held a cup under to catch petrol/coolant etc an that was it.. took about 30mins to do. nothing actually complicated about doing it.. straight swap, bolt off bolt on.
Hi!
Bushboy is offline Reply With Quote Quote
Old 07-03-2005   #4
Trader Rating: 1
When I fitted my Punto 60 Throttle body to my Cinq it was a striaght swap, did not depressurise anything. I swapped over the injector as I did not get one with the Punto 60 Throttle body. You could get away with using the top section of the 1108 Throttle body onto the bottom section of the of the Punto 60 Throttle body; meaning you don't have to remove any fuel lines. Just swap over the section of each throttle that holds the buttery fly. It is worth using a Punto 60 spacer as well as the 1108 Throttle body spacer has a smaller bore (30mm).
The vaccum pipe that connects to the under side of the airbox and runs to the back of the 1108 throttle body had to be removed as the there is no where to connect it to the back Punto 60 Thorttle body.
HTH
David
My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1
peaster2k is offline Reply With Quote Quote
Old 07-03-2005   #5
JonnyBoy's Avatar
Trader Rating: 1
Cheers guys, shouldn't be too bad a job then.
I'll just block that vacuum pipe off (it fits underneath my K&N) so that the engine doesn't suck any crap in through it.
Almost forgot about the spacer; has anyone got a Punto 60 spacer? Or knows how much they are from Fiat?
Old 07-03-2005   #6
Cento Boy
surfin_fella's Avatar
surfin_fella has donated!
They're about 4 from Fiat
Sie - Proud advocate of Centoism
Cinquecento60
Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum
surfin_fella is offline Reply With Quote Quote
Old 07-03-2005   #7
JonnyBoy's Avatar
Trader Rating: 1
Quote Originally Posted by surfin_fella
Top bombing! I'd best get one ordered ASAP then, knowing Fiat dealers it'll probably take longer for Fiat to get one in than for the TB to arrive
Old 08-03-2005   #8
i got one from my fiat dealer a couple of weeks ago, it was 6 something and 2 days for it to be delivered.
matt
Poor little Tarquin R.I.P.
now an 05 Corsa SXi <-- not a patch on Tarquin
littleyellowcar is offline Reply With Quote Quote
Old 08-03-2005   #9
Cento Boy
Right, now I'm home from work, I can properly reply to this!lol
As far as depressurising goes, just open the fuel cap and leave it off while you do it. Same with the expansion tank lid. You're gonna need new jubilee clips too to replace the "single use only" Fiat clips once the pipes are replaced. B&Q do some tiny ones, you only need 4. Make sure you have some nuts handy too to block up the pipes while you do the swap. I'd advise doing a pair at a time (ie. fuel first, then coolant. And swap over the pipes leading out of the tb first) There are arrows marked on the tb itself showing which way the fluid is to flow.
Make sure you plug everything back in too, that's always funny when you forget something!
Cinquecento60
(T) Special made throttle body for Cinq/Sei + Punto 55/60/75 Tricker... Cinquecento / Seicento 32 14-05-2012 22:18
(T) Throttle body Mrski1 Punto (Mk2/2b) 7 02-02-2005 18:06
(T) Care to enlighten what a throttle body is??? activematt Stilo 6 01-06-2004 20:07
(T) Throttle Body Cinq-tastic Cinquecento / Seicento 1 01-04-2004 03:22
