cure for addiction
cure for addiction
Yeah had to do this when my clutch cable snapped, would'nt recomend to do it all the time tho!
I have considerably more mods, THAN YOU!​
Pssssst my cars for sale​
oh, the noise in front of the car if you force the gears, only do this when its switched off. Did it to the panda once when moving, f**ked it up as well with a lot of noise. Well I was a new driver at the time and had to try things out... ended on the back of a RAC truck home :p
Shopping List:
-40mm Lowing Springs
Cadamuro Rear Spoiler
Window Tints
Scrapped 1.2 Punto
no when driving if you know how to do it you can go up and down the box without the clutch making no crunching noises at all. perfect for when you're feeling lazy and can be bothered to lift your leg up and push the clutch down!
Mick
Cinquecento Sporting
eldalie you spoil sport its all relatively harmless goodfun! im scared to try it from starting! just from second upwards. i found the rev limiter earlier fixit [}:)]. its raining so there is lots of wheelspin to be had! had to pull away in second earlier cos whels were spinning so much! it still spun too. i thought i was playing gran turismo!
Mick
