FREE to try Fiat diagnostic software
Re: FREE Fiat diagnostic software
Hi I've got USB 409.1 KKL VAG-COM OBD 2 II do I need to modify it to work with the other parts of FiatEcuscan (ABS,airbag,Elctric steering,Dashboard,Body,Serviceand Other)Works fine with the Engine just when I try to use the rest will no let me?
You will need The ELM cable. You will also need the VAG cable for Air Bag reset. You can buy a VAG cable with a switch that will allow you to access various options in the Fiat ecu scan program. These are on Ebay. But cost about £30 including postage.
Guys just bringing this thread back to life. Can anyone tell me if this diagnostics will work on a 04 ulysse? I don't see it listed but perhaps it will work? Also if i was to buy it what connection cable would i need? I know nothing about all this stuff but would love to have a go at plugging the car up and maybe fixing the odd gremlin rather than head to a garage all the time.
Contact the FES Forum - yani
he might be able to help
Can't see why not tho - another car/van with same ECU, cant use that setting to connect
And FES website tells you which cables will be needed for all cars, but as mentioned cant see ulyesse
Ziggy
Current version works only with K-line cables (KKL, VagCom).
ELM 327 is not supported.
i have punto which was first registred in may 2000 which code reader will work on it
Hi there i have a Elm 327 with the changable coloured leads. Red,yellow,green. Once ive scan the ECU with the red cable attached. Want to remove airbag light. A pop up window appears saying
You need a K-Line/Vagcom/OBDKey interface to connect to this module
Check your cable and serial Settings!
Ive chacked serial settings and im on com11
Is it one of these i now need
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_2573wt_1185
My punto is a 2001 Mk2 1.2 16v Sporting 6speed box
latency too high problem with fes 3.3 found a few thread on fes forums on this but no fix :(
any fix for this yet?
fiat croma 1.9 16v
laptop running win xp
latency too high,
port set at 1
trying to do steering wheel calibration, it fails says conditions incorrect
cant down grade to an earlier version of fes, unless maybe i uninstall 3.3 first, but cant remember where my code is so may have to pay again :(
Folks,
Recently changed the lockset, engine ECU and Code ECU, with ignition antenna etc - on my Sei... Will this software work on my car??
I've an engine management light on....??
Jon :eek:
