Chances are it's a wiring fault. The fan is running continuously, flattening the battery -- possibly even when the engine is switched off. (Check for this when you get the car started.)
On the Stilo I think the fan is controlled via the ECU and a relay -- likely to be switched on the -ive (earth) side.
Your best bet may be a mobile auto electrician if you don't have the manual.
