Old 24-10-2009   #1
Question High idle problem on 2.0 20v VIS engine
Hello dear members,
I am driving 1999 Fiat Coupe 20v VIS 154 hp.
Two days ago, I have cleaned throttle body and MAF sensor
because the car turned off on stopping.
After reasembling the parts, revs are on 1050 rpm on idle.
Sometimes they go up to 2000 rpm and then go back to 1050 rpm.
I have changed the ECU temp sensor, and tried with new Bosch MAF,
but nothing makes difference. I also reseted ECU, and that also
didn't help.
I have sealed the NRV (non return valve, that has little spring - it is located after the throotle body on intake manifold), and revs go down only by 50 rpm.
There is no false air that engine is sucking, also there is no vacum present when oil filler cap is removed.
I have double checked everything.
Any idea?
Cona is offline Reply With Quote Quote
Old 25-10-2009   #2
Talking Re: High idle problem on 2.0 20v VIS engine
Problem solved thanks to guys from Fiat coupe forum!
Removing the spring in NRV fixed the problem.
(T) injector problem on 20v vis engine sly_si Bravo / Brava 3 26-06-2009 20:44
(T) 20v vis engine.. MickeyBravo Bravo / Brava 2 08-06-2009 11:26
(T) Fiat Marea 2.0 20v High Idle Speed Dickie Marea Marea 3 26-09-2007 10:32
(G) BREAKING 1 x 20v VIS and 1 x 'normal' 20v HLX estates rjabell Marea 21 12-09-2005 12:19
