turtleautos
- Jun 12, 2009
- 3
- 2
just got given a mearea weekend 1.6 on a w plate even though im a mechanic i cant remember for the life of me the answer to this
right problem it
1.6 on a w plate 62thou mile
oil is filling boost bottle and air fillter etc and ending up going through the butter fly valve via the crank case breather, if the brether is disconnected dosent seem to be puffing at all. only when its connected does it suck oil up
done comp test and results are as follows
cyl 1 240 psi
cyl 2 230 psi
cyl 3 235 psi
cyl 4 235 psi
im probably just having a blonde moment
and help much appeciated
steve
right problem it
cyl 1 240 psi
cyl 2 230 psi
cyl 3 235 psi
cyl 4 235 psi
steve
