R Reece6845 New member Joined Mar 26, 2009 Messages 7 Points 3 Mar 26, 2009 #1 hay, im thinkin of buyin a cinq 1.1 sport and was wondering how easy the 1.2 conversion is? n will the 60 engine make alot of difernce to the speed and torque or mayb the 75 alot better? thanks reece :devil:
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Mar 26, 2009 #2 hi. welcome to the forum. i suspect this will be moved to the cento section soon check this thread; https://www.fiatforum.com/cinquecento-seicento-faqs/93884-engine-swaps.html the punto60 swap is a dodle and a piece of pi$$
OP OP R Reece6845 New member Joined Mar 26, 2009 Messages 7 Points 3 Mar 26, 2009 #3 thanks, do you have to make changes to the looms or is it a case of just plugging the original one in?
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Mar 26, 2009 #4 only difference is a 10mm exhaust spacer, everthing else is bolt for bolt. please read the link i posted, covers it all
