right indicator+left indicator
use the hazard warning switch, it does both indicators and its very easy to get to. i cant tell you the wire colout to use because i dont have a wiring diagram.
electric fan inhibit
your car doesnt operate the fan with ignition off so you dont need to do this.
door switch
all doors have a pin switch, its the pin that switches the interior light on. you can remove it by one screw to access the wires behind. i cant tell you the wire colour to use because i dont have a wiring diagram, but only one of the two wires will make it work correctly.
ignition input,
any ignition switched live will do, although you usually dont need to connect a switched live unless you want to use certain features such as auto door locking when you start the engine (its called anti-hijack and its very annoying)
vehicle immobilisation,
you already have a seperate immob fitted by fiat so you dont need to bother with this.
power supply,
use the glovebox light live, or the cig lighter live.
boot and bonnet switches
dont bother with them, they are not neccesary. opening the boot will trigger the current sensing system thanks to the boot light so the boot is covered anyway. if you want to fit a bonnet switch you can, it is very easy, but getting the wire inside the car can be tricky if you cant find the grommet hole to pass it through.
