Doblo 1.3 multijet engine knock
Wiz
Hi guys
I have purchased a new Doblo van with a 1.3 ltr 16 valve multijet engine.
I'm not sure about an engine knock or more a tapping sound on start up - sounds like a excessive cam follower clearance or the diesel knock you hear from the old black taxi cabs. I have noticed the noise after about 200 miles or more from new and only from cold, after it has warmed up it sounds like a modern diesel should. I have now done 6,000 miles and no change. Can someone please tell me if this is normal.
Thanks Wiz
i work at fiat and were always getting things like this on 1.3, always from cold, once things warm up its fine, unless u rele think its gonna shake its bolts off i wouldnt worry about it
OK Spooge thought that might be the case, thanks for the info.
Wiz.
