hi
could anyone help got home from work parked car just gone to start no go turns over great got spark(ouch) got fuel just wont go.
its an x reg 1.6 bravo . first ever problem
cheers kermit
if code light is remaining lit it means the immob is not switching off. try wiggling the wires to the left of the fusebox and giving the ignition switch a thump.
failing that, the most likely cause is the crank sensor.
hi all
thanks for replys and help much appriated
tried all but still no go got rac to come after two shocks from leads he decided it needed ecu no way everything present just wont go said he would tow to auto elec declined
borrowed mates computer plugged it in no faults found tried everthing .
went to old method set of plugs still no go set of leads brum of it went on testig leads no 4 lead had broken down hope this helps others
cheers to all have a good day:worship:
