16VT in a Tipo Sedici
Sedicivalvole22
Kent
Right basically I've heard this can be done and there are a few out there so please if you've done this or know somebody who has I need advice and potentially sources to what I need to get.
I'd like to get a Fiat Coupe 16v Turbo engine (that of the Integrale but obviously setup for FWD) to put into my Tipo Sedicivalvole.
I hear it's a straight swap and has been done before. Obviously the ECU differ slightly but I hear it can run on almost the same loom with a few more wires added in.
I've seen it on Bebo and I know it's been done a couple of times now I really fancy doing it to mine so I need all the help I can get please team!
No I convert Tipo, he keeps Bravo, has my engine from Tipo that is blueprinted and rather quick and everyone lives happily ever after! lol
Because I've been told the 16VT is almost a straight swap where as the 20VT needs lots of work to fit and modifiying. This is why I need more info people!
i thought you'd say that. :)
i would buy a coupe manual from ebay, and a tipo one as well. then you need to compare the wiring diagrams to see what the differences are, and also compare positions of equivalent sensors. then you will know what differences there are and what wiring you need to modify/make.
Good idea...do you know what you're doing then? lol, give me a quote to fit the engine and get her running and I'll do the rest :p
