Fiat Marea Radio
Fiat Marea Radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
plh1604
United Kingdom.
I have a fiat Marea, unfortunately i don't have the radio manual for it.
Currently the radio does not turn on/off with the ignition and has to be done manually.
Is there a way you can set the radio up to operate along with the ignition...??? maybe a combination of buttons that need to be held down to activate this..???
Any help appreciated
[8D]
On the AD185H model you need to press the MUTE button for about 3 secs, then you will see either IGN ON or IGN OFF on the display. Not too sure if the radio has to be switched on or off first.
If you have the AD185M model with the volume knob then as custard says you may have to change radio feeds, not sure how that will affect it's memory though.
Alternatively, remove the thing and install a decent HU :)
<font face="Verdana">-- T.
<font color="maroon">'98 Marea Weekend ELX (1.8 16v).</font id="maroon"></font id="Verdana">
