im Axle Specialists
Old 09-05-2004   #1
Mass air flow indicator
Can anybody help recently got a marea2.4jtd that was running very sluggish. Having read other postings i decided to disconnect the mass air flow indicator. the results were imediate. I'm assuming that the engine has been running very lean (hence 40+ mpg).
Does anybody know the cost and availability of this unit.
And are they common accross the range as a local breaker has a jtd in.
DAlex
DAlex is offline Reply With Quote Quote
Old 09-05-2004   #2
try cleaning the MAF sensor out with break/carb spray cleaner ( dont touch it with anything else its easly damaged )so dont scrape it clean, a good spray will do then try it out
1.6 elx 16v my baby
carman is offline Reply With Quote Quote
Mass Air flow Meter DAlex Lets Talk FIAT 12 18-01-2014 12:42
(T) intermittent indicator problem Andrew Hosfield Marea 8 04-03-2005 16:44
(G) 120 indicator on Abarth Speedo?? kat Stilo 11 25-08-2004 21:04
(T) Problem with indicator and headlights rob88 Cinquecento / Seicento 1 03-12-2003 17:29
(T) type of Bosch mass air flow sensor? henrikjuul Marea 5 29-05-2003 16:55
