Batterstyle
Can anyone give any clues? 85S Regatta intermitttantly miss-fireswhen the throttle is pushed down slightly during acceleration. If you push the throtle down further it smoothes out. Then for no reason it will run fine for the next few times it is driven. Then with no warning either while you are driving, or the next time you get in it will miss again. If you pull the choke out a little it runs smooth albiet ar a high idle. Have checked ignition timing, idle mixture,drained fuel bowl, replaced fuel filter, replaced spark plugs????? Any ideas? It sounds like a carby problem to me?
Batterstyle
Batterstyle
