Brake Master Cylinder fekked??
euro
Lincoln
Anyone got a quick n easy way to tell if a brake master cylinder is kaput please...
When brake MC's go bad they usually leak fluid either between the MC and the vacuum booster or directly inside the cabin under the dash, were the rod from the brake pedal goes through the firewall...
Hope this helps... If not, what are the problems you are having?
:D
1980 X1/9 "Celeste"
"Real men love hugging tight curves"
