![]() | #1 | ||
Posts: 1,563 Thanks: 4 Trader Rating: 1 ![]() | How to fit a Strut Brace? Hello all ![]() Big smiles because me Strut Brace arrived today ![]() Now, how do you fit them? is it a simple case of unscrewing the Bolts at the top of the strut, attaching the afformentioned strut brace then Screwing the bolts back? Or would I need to raise the car off the ground first so the car doesn't fall over when I uncrew the bolts? Ta ![]()
![]() | #2 | ||
Posts: 1,936 Thanks: 0 Trader Rating: 0 ![]() | Re: How to fit a Strut Brace? bolts off, brace on and then bolts back on
![]() | #3 |
Posts: 23,471 Thanks: 426 Trader Rating: 1 ![]() | Re: How to fit a Strut Brace? I know it is a different car, but any tips in here: https://www.fiatforum.com/stilo-guides/47410-how-fit-front-upper-strut-brace.html
__________________ See you next Tuesday ![]() |
![]() | #4 | ||
Posts: 1,563 Thanks: 4 Trader Rating: 1 ![]() | Re: How to fit a Strut Brace? ![]() I know it is a different car, but any tips in here: https://www.fiatforum.com/stilo-guides/47410-how-fit-front-upper-strut-brace.html ![]() I'm gonna do it Beasty's way ![]()
![]() | #5 |
![]() | Re: How to fit a Strut Brace? The car won't fall over, as the car's weight will keep the tension on the springs anyway... Just make sure there's nothing in the way of fitting it, on the Punto there is the brake fluid reservoir and on the higher models (i presume) there is the power steering fluid reservoir. Good luck mate... is your car still working after the ACE meet?
__________________ ![]() CinquePunto - Five Point Photography - Adam |
![]() | #6 |
![]() | Re: How to fit a Strut Brace? ![]() Feeeeeeeck I need to drill stuff?? Aww man ![]() I'm gonna do it Beasty's way ![]()
__________________ |
![]() | #7 |
![]() | Re: How to fit a Strut Brace? ![]() Just make sure there's nothing in the way of fitting it, on the Punto there is the brake fluid reservoir and on the higher models (i presume) there is the power steering fluid reservoir. Are you talking about a mk1 or mk2 punto? The Mk2's don't have power steering fluid...
__________________ NA8C Eunos Roadster - Epic fun ![]() ![]() ![]() www.puntomk2.co.uk - For all your Punto Mk2/2b/Grande needs.... And some awesome banter ![]() |
![]() | #8 | ||
Posts: 1,563 Thanks: 4 Trader Rating: 1 ![]() | Re: How to fit a Strut Brace? ![]() is your car still working after the ACE meet? ![]() And the petrol now lasts way longer ![]()
![]() | project-cinqy | Cinquecento / Seicento | 3 | 09-10-2005 21:37 |
![]() | CinquePunto | Punto (Mk1) | 3 | 30-06-2005 19:27 |
![]() | lalli | Stilo | 18 | 24-04-2005 20:59 |
![]() | Spudgun_mk | Cinquecento / Seicento | 10 | 14-12-2004 19:02 |
![]() | beastyjay | Cinquecento / Seicento | 15 | 17-07-2004 02:23 |
