mrs daves new car has start stop but it also has a turbo. but you shouldn't switch off a turbo engine straight away but car will do it on its own :spin:
There's a good chance the turbo is watercooled but even if it isn't the tolerances in them are much better and they are better built than 80s and 90s turbos. However if you want to allow it idle you can, just don't fill the pre-conditions for the stop start. So if you've been on the motorway don't lift the clutch in neutral until the engine has idled for a while. If its an auto switch the stop start off out of town.
We've had turbo stop start and you can manage when it stops the engine.
There are something like 25-30 pre-conditions for stop start on the Citroen to work so turbo temp could well be one of them tbf.
ah this nissan might have some of them then would explain why it dint stop and start on the way home after i got it or when mrs dave took it out today.
sounds like a big heap of stuff that could all go wrong one day.
it wasn't from a forecourt it was a SureCheck Gold, grade 1 auction car.
this one seems to reset to on every time i turn ignition off and on again.On our new Giulietta 1.4 Turbo, we just switched the start/stop function off, small button on the dash...easy.
Don't like this engine behavior at all.
how does that work alternator is still going around if its switched offMost of it is stuff a modern car would monitor anyway, it uses data the car would already collect for a different purpose. E.g. it already monitors battery condition and power draw as modern cars shut off their alternator when the battery is full to reduce ancillary drag and save fuel.
Going back to the qashqai i'd be more concerned about watching engine oil levels in the 1st few weeks rather than what the stop start is up to. From what I've read some Renault Tce units (so qashqai and kadjar e.t.c.) left the factory with slightly small pistons resulting in lots of oil use and eventually new engines.
Hopefully won't affect you but keep an eye as some people have missed the oil use and only realised when the oil pick up for the timing chain could no longer get any resulting in timing chain death rattle.
