Has anyone come accross a Groeneveld speed limiter(http://www.groeneveld-group.com/index.php?id=106&productid=1120), if you have how is it removed?
Does removing it not sort it
unplug it
torx bits undo, quick search on google
Tried that, doesn't work, no throttle control if its unplugged.
ill have a look later after gearbox shenanigansIts not that simple(I don't think), I found this, have a read(PDF attached).
I think this will be pretty much the same way as the old school tachographs worked when the speedo wire (Whatever it is) goes into it so it can get the speed, the has an output cable for the actual speedo. Maybe bypass it?
Whats it connected to? Fly by wire throttle
