half way through redoing the kicthen atm, (by halfway i mean we ripped it out to run new pipes for the boiler and now have no kitchen at all) and because of the steelwork that has gone in, we're dropping the ceiling. great time to fit some new halogen spot lights. so went off to buy some, but couldn't decide which to get low voltage, or mains voltage ones.
mains voltage ones were rated at 50w. so that is 50 / 230 = 0.22A
lower voltage ones were rated at 20w. so that is 20 / 12 = 1.66A
current is much higher on the low voltage ones, but because they're lower voltage - the actual current draw is higher.
sooooooo basically, the lower voltgae ones are only going to use less power because they are 20w bulbs and therefore not as bright as the 50w bulbs, yes?
