12 to 5 Volt transformer
East Yorkshire
Thought I'd post it here as it doesn't really fit ICE or security and isn't really car specific as such,
What im looking for is a regulated power supply able to deliver 5Vdc (not sure about the current yet as the unit hasn't arrived)
i have found plenty of the plug into fag lighter adjustable type units
such as this
1.5, 3, 4.5, 6, 7.5 9, and 12 volt supplied at 1500mA Maximum
at a guess i am assuming the unit might work of 4.5v but i want to do it right if i can
its to power a DVR which will be used as a Accident CCTV monitor after seeing what venomco did in his GP with an Archos I have gone for a cheaper option and one that i can fit semi permanently under the drivers seat or back seat
one of these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=230239784118&Category=48632&_trksid=p3907.m29
anyone any ideas please?
Cant see an issue Andy, the recorder needs 5vdc and draws 350mA (0.35A). The voltage regulator will deliver up to 1500mA (1.5A). The CCTV system I installed at home is something similar, it runs on 6vdc despite the specs calling for 5vdc. I always assumed the recorder has its own built-in voltage regulator which protects it from under/over-voltage.
