Move Completed!
Move Completed!
Welcome to the new Fiat Forum... as you may have noticed, everything looks a bit different, but believe me, this is not the only change.
We are now running vBulletin forum software rather than Snitz, which is an infinate improvement, search works for a start!
There's a bit of a learning curve, but some default FAQ's should help you out (check the grey bar at the top) - you can now also attach photos with posts, upload your own avatars / profile pictures and loads more, a list will go up in the next few days :)
Apart from that, ENJOY!
Nice one, well done Ben!! :D
What's happened to member titles though??
Looking good Ben!
Looks more modern, a bit different...
Noticed that theres no links section and you have to get your own smilies for the message.
Ive found out that if you just type in :) , etc for the smiley you want, it will automatically be turned into a smiley!!!
One good trick - in User CP and then Edit Options - turn on the full WYSIWYG text editor; smilies can then be picked from a drop down menu.
Also note the new 'full screen' mode, selectable from the very bottom of each page :)
If you change from basic to standard formatting, you get all the smilies in a little box on the right of the text box! :cool:
And it might be good if you have a set limit on the size of peoples sigs, ie max width and height. I seem to remember on the old forum peoples sigs started to get huuuuuge!!!
ok, active topics is now called - New Posts
Smilies are automatically converted, you dont need to square brackets around things.
Your user title, if you have donated, can be changed in the control panel (no need to mail me anymore :))
Oh, and down the bottom there is a drop down, which will probably say 'FIAT Forum Traditional' - change this to 'FIAT Forum Traditional (Full Screen)' for obvious results ;) (it will save the option for you)
Apart from that..... any more questions... (just dont ask about PM's, i know the counter doesn't work, got a support ticket out with vBulletin, so they can fix it...)
Ben, is there any other way of donating other than paypal?
And i hope the link section will be up soon, i used that to find decent companies and websites for my mods.
also you can leave people feedback on the posts they make - whether you think the post made was good or bad - it is anonymous as far as i am aware.
but remeber you have to spead your reputation around before givivng it to the same person again ;)
