Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fault code reading - Idea - socket location + access<!-- google_ad_section_end -->
Published by varesecrazy
05-07-2014
Difficulty Level: 1
User Rated:Unrated
Socket - plugging in
with the panel out of the way,
you'll need to get down on your knees ( outside the car), and look for the socket..,
I'ts well packed in - surrounded by cables and fusebox(es)
Name:	may 14 144.jpg
the Black Device + WHITE cable are the MES lead and Multiplex adaptor , actually plugged into the socket.
2nd view ( bit blurry)
Name:	may 14 145.jpg
with it all connected you can use your Code Reader,
or in my case MultiECU Scan
Name:	may 14 146.jpg
thanks To @dombooth for his assitance with the Multiplex.
Likes isthisagoodidea, ideadrive liked this post
Contents
<<  <    (Page 2 of 2)    > >>
Old 04-07-2019   #1
Greece
Re: Fault code reading - Idea - socket location + access
Very interesting varesecrazy...what do I need to use this connection ( if I ever need too.)..you talk about a code reader or amulti ECU scan ...can you tell me how I get hold of either of them ...I'm in Crete ...many thanks ..edit I'm guessing on my lefthand drive Idea this connection is on the other side ?
isthisagoodidea is offline Reply With Quote Quote
Comment
Search this Guide:
(T) early Sei fault code reading bungler Cinquecento / Seicento 12 29-03-2013 17:14
(T) Fault code reading weealan Sedici 0 21-09-2012 13:45
(T) Fiat Idea 1.3 Multijet fault code 0106 Jehu Other Fiats 5 06-11-2011 12:50
(T) Possible airbag fault code reading SouLz Punto (Mk2/2b) 1 30-10-2010 22:34
(T) Fault Code Reading and Air Bag Light Adrian141 Punto (Mk2/2b) 2 11-11-2006 21:06
