Hi all, first up, great forums. I've usually found what I've been looking for on the forums so this is my first post. I'd like to say hi to all.
I've fitted a Sony Xplode head unit in my Brava 1.4s. I did have a pair of Infinity 6012i's (160mm) in the doors but they sounded pap due to not fitting right. I mean by this that pressure from the back of the cone able to escape round to the front causing flat spots and inadaquate bass.
I've now put in a pair of Apline 75C2's (5x7") which sound pretty nice.
I was wondering:
1) Properly fitted which are considered the better speaker?
2) Any chance the Alpines could be fitted either side of the parcal shelf?
3) The car has no wiring to the rear apertures. How would I go about running this wiring and how would it connect to the block behind the stereo?
4) If I'm running wires front to rear, would there be any prep work I could do incase I decide to add an amp/sub later?
5) Any tips on how to properly mount the Infinity's properly in the front?
I've tried using google to answer all these questions to no avail. Any help or links to guides would be much appreciated.
Ta
I was wondering:
Ta
