The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Bravalady
South Yorkshire
Hi
I wondered if anyone could help me with a little problem.
I have just bought a second hand Fiat ~Brava Radio with no listed code.
Phoned a Fiat dealer and they said without the code, the radio won't work with my ECU. I have my own code tucked away safely, so I take it, that this code will not be suffice? Has anyone else have any ideas on the subject? Or shall i return the radio to the seller?
I have sent back a stereo to be replaced and it's going to take a couple of weeks, so I've put the standard fiat radio back in but I need the code. Can anyone help.
these are the numbers that are on it;
BP - Nr 7 649 372 316
and
735 272 569
and
BP9372Y1170807
i'm sorry, my code generator is for Visteon radio's. However if you do a search on the internet for Blaupunkt code generator / radio code I guess you will be able to find some - there are plenty of them. Do a virus-scan if possible!
good luck!
I.ve managed to get the code and entered it , but now all I get is the word WAIT. I've waited and waited but nothings happening. Any help?
good luck!
Hi Yellow. I'm a fellow stilo owner with a visteon, so can you supply me with a code??! Much appreciated if so! :)
Blaupunkt / Punto radio code ?
Can anyone help > I have an 02 reg punto with the original radio but do not have the code to enable it ? Is there a standard code that someone can give me or is every radio unique > any advise...............
Re: Blaupunkt / Punto radio code ?
If i remember the Code should be on a peice of paper that came with the car, Guess might have been lost, Try this take the stereo out on the Right hand side there is a sticker it might be printed on there.. Worth a try
Blaupunkt code
Hi all,
I get the impression that the Blaupunkt IDC A09 CD changer ain't the most reliable bit of kit around. The one in the car when I bought it was kippered and the first one I bought off ebay was also kippered. :mad:
Now I have acquired another unit which at least asks for a code. It is showing CD Code and ----. Trouble is, as you've probably guessed by now, I don't have a code for it. :eek:
S/N is either BP 915035374495
or
7 607 769 150
Can anyone supply a code from this information please. :worship:
Re: Blaupunkt code
:worship: Fantastic..............It worked.
You're a star, and should we ver meet then the beers on me :)
Re: Blaupunkt code
Well i have a F iat Punto and the blaupunkt radio need a code (XXXX).
I write the numbers information, if somebody can get the code i´ll very grateful.
Prod.nr fiat
735289639
BP nr:
7649372316
another numbers:
8 631 122 610
bp 937 215 368 724
This is all information that i can to give. Please Help me!!
Hi Give Me Bp Number And Head Unit Model For Example Grande Punto Bp 123456789123 The Bp Code Is 12 Number And On The Head Unit Chasis
