Are you sure the serial number is correct? It's one digit too long.thanks but 2111 is not working
Yes that did it!!Please try 1444
And let me know if it works, as I'm currently writing a new calculator and need to test it
Fantastic, thanks for reporting backYes that did it!!
Thanks!!
Try 6635Sorry you re right, i made an error.
Part number - 7 647 389 316
The correct serial number
Serial number - 815 BP 738976733449
I've just written a calculator for this and you can be the first test!Hi I'm looking for a code for Continental radio , Abarth 595
Ser # 24980
PN: 07356791360
Thanks,
If you didn't find it already, please try 7658 and let me know if it worksHi Davren, thank you for your prompt response! The serial number is Y2432, if I am relaying correctly what’s attached.
Hi krispys, that's a different format than I'm used to (the BP number should be 12 digits), but see if 6646 works.
I will try in a bit, here are photos of every number on the radio. If you do mot mind what should the serial start with?Hi krispys, that's a different format than I'm used to (the BP number should be 12 digits), but see if 6646 works.
If that doesn't work, could you please let me know the model number of your radio.
Yes, that isn't the serial numberI will try in a bit, here are photos of every number on the radio. If you do mot mind what should the serial start with?
BP534353895043? @benYes, that isn't the serial number
It should be in the format BPxxxxxxxxxxxx (BP and 12 digits)
Yes, try 2223BP534353895043? @ben
Worked like a charm. Much appreciated!Yes, try 2223
