The one and only code for fiat radio thread.
Sh*t and F***. Twice. Apologies for the language and for making an arse of a simple task. Must be age or drink or both. Or maybe too much of the first and not enough of the other....
Davren - i gave the wrong serial number - it should be M189941 not the M189944 i gave before - any chance of getting the code for this one?
Thank you.
Hi all, i need your help please, i can't find my radio code for my Fiat Multipla
Numbers i found on the radio are:
CD423/64
VDCD76620005226
A2C53194701
CG0006290005226
Thanks in advance!
CD423/64
VDCD76620005226
A2C53194701
CG0006290005226
Thanks in advance!
Sorry.... I don't have codes for VDO radios.
The only way to get the code is from a Fiat dealer, or at a car radio workshop.
Hi all,
Hoping someone can help me get the radio code for the radio in my 2012 Doblo.
Numbers at the back are:
FIAT F263 (dobl) [MVRA]
17150010368017
And at the rear:
HW VERSION 28252885
SW VERSION 17
7355012410
F263 EUR 2410282528851026403034
P/N 28252891 SN:000711 DATE:020910
If nobody is able to retrieve the code, then please let me know which eeprom to read it from and whether it's the radio module itself or the BCM.
Thank you in advance,
Ruain
Hi all,
17150010368017
And at the rear:
HW VERSION 28252885
SW VERSION 17
7355012410
Ruain
Codes for Delphi radios can't be calculated from the serial number.
I believe the EEPROM is a 24LC32 in the radio.
Thanks Davren,
Once I have the dump from the eeprom, is there a software you'd recommend to extract the radio code, or should it be obvious from the output?
First of all, I would like to thank and regards all the forum friends.
I have an old radio Blaukpunkt and i missed the radio code.
This is the details of radio:
On a white label there is this number
BP NR 7 642 375 316
PROD NR. FIAT 735 337 934
On the metal there is this number:
BP237536864284
You can help me find the unlock code
Thanks you all and congratulations to the beautiful and helpfull forum
BP NR 7 642 375 316
BP237536864284
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Please can you help me with code for my cd changer. I has donated the forum.
My serial number of cd changer is : BP915024340231
BP Nr. 7 607 769 150
Prod. Nr. Fiat 735 273 184
Hello,
My wife and daughter both drive a Fiat 500 and i want to swap te radio's because my wife has a radio with AUX option.
Can you provide me with the codes of both radios?
Fiat 312 MP3 Aux Black
7 640 391 316
735 523 958 0
815CM0391A0941456
Fiat 312 MP3
7 648 572 316
735 516 141 0
815CM857298752095
Thank you very much from the lowlands :)
