Bravo Headunit
Bravo Headunit
Lostwithiel, Cornwall
Can u see my problem?? thats as far as it will go in..
Help!
Adam
** Now A Bravo Owner :D:D ** ** (96) 1.8HLX Bravo **
you need to take the glovebox out and pull the wires down the back to the left, its realllllly tight but it can be done!
- - Donz - -
when i say down the back to the left, i mean behind the headunit, there is a hole there that goes to some free space behind the glovebox, but you can only pull the wires down that way if you take the glove box out, which is done by removeing shotloads of screws from inside.
- - Donz - -
oki kool i guess that will gime a chance to wire up my amp and sub too then running the wires that way. Just noticed aswell that the settings on the cd player are not gettin saved so must be somin todo with ignition and constant live wrong way round? ne one else had this problem?
Also where is the best place to run a feed from battery through into the car. looks quite complicated under the hood comparaed to me nova [xx(]
When I was fitting the cage into the facia plate today I noticed I had to push it up to get it fully in.
Whats this about the live and ignition being the wrong way about. I noticed my settings wearnt being saved so what would I need to do to sort this one out ?
Scorg
02 Stilo Dynamic 1.6
Sky Blue
01 Brava 80SX
Ink Black
what about those two cables that go into the top connector on the brava head unit, they have any use at all or can those just be ignored ?
Scorg
Sky Blue
01 Brava 80SX
Ink Black
