Co axials .. what the hell
you can replace the rear speakers if you buy a speaker bracket... the link is on another thread i'll see if i can remember where it is..
the bracket will allow you to fit 130mm speakers where the 100mm speakers were before...
Whats wrong with the standard locations?
Matt
______________________________________________________
Signature space for rent, reasonable rates, apply within.
While most Cinqs are unreliable...mines just taking the pi55
what would you call the standard locations .. the door doesnt have any speakers anyway .. and i am not gonna cut holes in them .. and they are too big for the rear .. unless i fit them on the parcel shelf a bit like a 6 x 9
It has no standard speakers?
Matt
as i said you can fit 13cm speakers where the 10cm speakers are in the back using the aforementioned brackets which should improve things and you can get 3.5" (or 87mm) co-axials for the front.. motor world at the moment are selling off JBL co-axials and they do the odd 3.5" size...
though if you've got a mk2 punto then all of that info doesn't apply... but as you don't have door mounted speakers then i'm assuming it is a mk1!!
