Thread Tools
Old 12-09-2005   #1
The Older Modder
steve1219's Avatar
Trader Rating: 2
steve1219 has donated!
Chroma Blast Champion, Torpedo Joe Champion
Pwr Drain
Hopefully a simple question, never had this problem with the install previously but have just upgraded the subs to approx 2000rms now even at a quarter power the car lights respond to the bass beat, I am still using the 1F caps per sub, do anyone know if upgrading these to 2 or maybe 3 will stop this effect or do I have to look into upgrading alternator etc
TIA
Steve
Never drive faster than your Guardian Angel can fly!!
You can only be young ONCE, but you can be IMMATURE for EVER!!
Show you car with Fiat Forum check out the EVENTS section for a show that fits your style
steve1219 is offline Reply With Quote Quote
Old 12-09-2005   #2
paulbfd has donated!
Re: Pwr Drain
Do you mean you've upgraded the amps for the subs to 2000wrms?
At this sort of power, you could be pulling nearly 300amps, power caps ain't the way, more batteries and a bigger alternator is.
Black Panda 100HP
Alpine CDA-7944 headunit / Audison Bit One processor.
Audison LRX5.1 / Hertz MLK2 & Audison TH Basso.
Chord Epic speaker cable & Anthem 2 RCA leads.
paulbfd is offline Reply With Quote Quote
Old 12-09-2005   #3
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
Re: Pwr Drain
Quote Originally Posted by paulbfd
After seeing your install, an optima yellowtop battery and uprated alternator will more than likely cure the problem
Luke is offline Reply With Quote Quote
Old 12-09-2005   #4
Re: Pwr Drain
Black Panda 100HP
Old 13-09-2005   #5
Re: Pwr Drain
powercap will help
but would be better with alt + batt
powercaps work by using the charge they can hold when the bass kiks in and charges when there is no bass on the amplifier or power being used by it
phil_GT is offline Reply With Quote Quote
Old 13-09-2005   #6
Trader Rating: 10
dave has donated!
Re: Pwr Drain
Quote Originally Posted by phil_GT
powercap will help
steve has power caps 1Fs, he is an Electronic Engineer so i think he knows how they work
Old 13-09-2005   #7
The Older Modder
steve1219's Avatar
Trader Rating: 2
Re: Pwr Drain
No actually upgraded the speakers to enable me to use the 1000wrms per speaker so I have basically increased my pwr draw by times 2 on the sub o/p. These are capped at 1F.
The rear outs which I am using for more of a 'mid' / 'filler' range bass which is not capped at all - wondering wether this one should be- through 12" subs and 'mid' / 'filler' range on the HF range - 6x9 ( for those that say 6x9 are no use I agree if used for bass when using a sub but have found using them for mid -high freq seems to fill a gap in the spectrum - could be just me but I am happy) these are fed by approx 200wrms.
Componat speakers at the front are driven by approx 150wrms x 2 sets.
So total pwr is about 2700wrms or 5170wpeak.
Been looking at the yellow tops and think I will try that route first once I get the money together .
Anymore advice always ready to listern.
Steve
Thread Tools
(T) where is the transmission fluid drain plug??????? colleen Punto (Mk2/2b) 2 07-08-2010 18:24
Gearbox oil drain plug & rear brakes hangten Car Care 1 28-08-2005 18:06
(T) Sump drain plug size ???? scatcat Punto (Mk2/2b) 2 17-06-2005 22:01
(T) Punto Gearbox oil drain plug?? Gandorf Punto (Mk2/2b) 3 22-02-2005 10:17
(T) Air Con Drain tube Question hatters1999 Bravo / Brava 5 23-10-2004 23:30
