Hi All
The instructions below describe how to access a few in-built diagnostic tests the Visteon Stereo's have in-built:
1. Turn the Stereo ON
2. Press buttons "3" and "6" together for a few seconds, until a pitch note is heard on the speakers.
Now you're in test mode, here are the tests you can do:
A. SPEAKER TEST - Pressing the ">>" button will test all the (8) speakers the car has - 4 speakers, 4 tweeters. Once finsihed, it will exit the test mode, and you'll have to go back in (above).
B. SIGNAL STRENGTH - Whilst in test mode (with the pitch note heard), press button "3" again. An indication of the intensity of the radio signal the tuner is receiving is displayed as a measure of voltage (e.g. SIGNAL STRENGTH 1.6V). My averages are 2V-3V.
C. SHORT & OPEN CIRCUITS - Whilst in test mode (with the pitch note heard), press button "6" again. Check that the words "SHORT CIRCUIT - OK" appears (i.e. no problems).
D. PROCESSOR & MODULES COMMS TEST - Whilst in test mode (with the pitch note heard), press button "1". "COMMS TEST - PASS" should appear.
E. CHECKSUM (internal EEPROM) TEST - Whilst in test mode (with the pitch note heard), press button "4". "CHECKSUM - PASS" should appear.
F. DISPLAY OPERATION TEST - Whilst in test mode (with the pitch note heard), press button "5". All the pixels on the display should appear.
To exit the diagnostic test, turn the stereo off normally.
Hope this helps in some way.
