Blaupunkt Radio switches itself on. Solution.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
xatabay
It seems from a number of posts that it is fairly common for Blaupunkt head units to come on by themselves - draining the car battery. Here is a cheap and dirty solution:
Buy ( Maplins / eBay / Halfords ) http://www.ebay.co.uk/itm/Draper-5m...ter-Adapting-/400434310304?pt=UK_BOI_Electric £6.90
Pull radio out of dash ( need extraction tool or some stiff wire ).
Replace the main radio fuse with test lead.
Connect a switch to other end of lead.
Route behind dash - this is the hard part.
Now the new switch will completely switch off radio.
