Hi guys im wondering if you can help me out. Im currently running two vibe 12" SLICK sub woofers in my car. With 2 Vibe slick amps. These amps came with the sub woofers. I have wired each sub to its own amplifier in bridge. With both amp settings the same. Single power wire to connection block with in-line fuses which separate to each amp.
Problem
The audio works fine. Can crank it up works fine. After about 30mins or so the subwoofers cut out. Even on low level. Both amps lights go off and the amps are cold to the touch. If i switch the car off and on makes no difference. But if i leave the car for say hour or two and switch the car back on again. Everything works fine without touching anything?
Would a capacitor help this?
Any ideas?
here is a link to the subwoofer/amp
VIBE 12" SLICK SUB & AMP SYSTEM PACKAGE 1: Amazon.co.uk: Electronics
Problem
Any ideas?
