I got a punto evo and i am waiting to fit a sub and amp. is this going to be difficult due to the stop start connected to the battery? can anyone advise how to wire it safely?
thanks
i fitted on mine and didnt find it too hard n nor does it effect the stop n start too much as long as it is too power as it can drain the battery n cause the stop n stop not always to work, as mine does.
if stop n start stops workin turn radio off n let battery charge for a pic, it wat i do .
hope helps
If you look at my posts etc you will find this is quite easy, if you have the blue and me equipment you will need a crossover for two extra Aux connectors for the sub.
