im about to build my first sub box into my spare wheel well, the sub is a
pioneer TS-W307D
Features
Maximum output power 1.200 Watt Nominal output power 400 Watt Frequency response 18 - 500 Hz Sensitivity (1W/1m) 89 dB Woofer size (cm) 30 cm Woofer material Composite IMPP™ cone using Interlaced Aramid Fibre with reinforcement arcs Voice Coil bobbin type Phenol resin coated glass cloth bobbin Pole Yoke Type Extended and Vented pole yoke Magnets Double-stacked Recommended sealed enclosure (Litres) 24 - 49,6 litres
my problem is the size of the box i need to make based on the 24 - 49 litres, can any one clear this up for me so i knw the mesurments i need for the box?
pioneer TS-W307D
Features
