Hi Everyone,
Quick question - I am again for the third time in my third punto looking to wire the door speakers to an amp in the boot. I have a few technical questions though.
My model is the HGT and it has much more electrics running through the door tube. Anyone has a clue which wire relates to which etc...?
From what I've seen thus far there are 2 wires running to the tweeter and two running to the mid range/ bass unit (<-- or whatever you can call that tiny thing that trumps rather than gives out sound) Presumably Fiat must have a crossover built in somewhere to split the signal from the headunit?
I am trying to fit infinity perfect kappa 6.1 components in but the crossover that comes with is mahooosiiiive!! will more than likely fix to the door card either on the inside or drill a couple of holes in to the plastic at bottom of door card and run the wires through from main feed/ tweeter and mid range cone and route to each component accordingly.
Really need a little help from someone in the know here - Any advice welcome. I have done this before on an old mk2 punto by opening a larger hole in the door tube and running new speaker wire through direct to crossover and then connecting tweeter and woofer. This worked but of course left wires hanging around doing nothing. I doubt adopting this technique will work on HGT as there doesn't seem enough room to get more wire through the door tube....
