Hi, i have 2 12" vibe slick subs and they are both being powered by a vibe a7 amp, and when i was messing with the settings on the sub, say the gain is at about 3/4, when you slowly turn up the bass boost, there is like a section where you get a really bad popping /crackle, and if the gain is at a different setting then the crackle will happen at a different level when the bass booster is change and so on...
The crackles volume doesn't change when the volume of the headunit is changed, and i have a bass booster remote dial at the front of the car and when i hold the whole thing in my hand the crackle souns slightly changes, ( its metal )..
The sound doesn't change when you accelerate, but does when you turn the hazard lights on as the crackle seems to follow the sound of the "ticking"
Also strange that there is no crackle when the ignition is on, but only when the engine is running.
Phwoar! lol, thats all the info i can give you really, hope someone can help lol
