Sorry you will have to bear with me here as i only know the thickneses of cable by eye but Noooo. Im pretty sure that the speaker cable can potentially be too big if you are not puting enough power through it.
Also remember that if you have to trim it down to fit your connections then you are wasting your money. I would think the 14 gauge would suffice for front speakers especially considering that is a bit of a push to get into most spade/bullet connectors without coning.
Big wire does look better though :devil:
Soz, i meant to write 12gauge. Kinda thought that about the whole size into spade connectors thing and went down a gauge.
Thought about it though and the only connector I am planning on putting on is the spade terminal to the midbass. Will run everything else as continuous runs. The amp can take massive cables, and the crossovers have pretty chunky connectors too.
P
