planning on building a custom boot box in the wheel well, if i make the box the same volume, with the same sub and port will this give the same sound? or am i likely to get a different sounding sub when i'm finished?
Please anybody who does this can you use a calculator on here.
http://www.the12volt.com/caraudio/boxcalcs.asp#cyl
A box is extremely easy to make too small and if its too small it will sound rubbish.
I have seen people try to make these and they are a fair bit of effort and because they are too small, they have ripped them out and started again.
Also if you are doing a wheel well box i would recommend using a 10" sub for numerous reasons. The chances are that it will end up sounding better than a 12" if you arent experienced.
If you are looking for 10" subs i can thoroughly recommend the Diamond D3 subs they are fab :devil:
To get the required volume for two 10's in my Sei, I mounted them arse out, no reason you can't do that with a single 12.
Like Stu said though, soundproof the boot floor first, the FG with mould over it nicely.
I actually meant layers of Deadening inbetween thicknesses of FG but yeah deaden the wheel well first obviously. I would also use soundproofing material (luxury liner pro) in the well to stop vibration between the the two hard surfaces.
going to start this weekend, have taken my sub apart already, and worked out the internal volume of the box, so going to make the new one the same volume but round, still with the same port, and same amp
6"!!! i'm sure its far deeper than that gonna have to go check that out as will scupper my plans entirly!
so it should sound as good as it does now *fingers crossed*
i'm going to make the round box outta 6 pieces of plywood, bent into a jig and glued together x2
hopfully this will give me 2 semicircles to play with, plannin on putting all the pictures up next week once done if it all goes to plan
i'm also gonna build a console for the tyre pump and other bits to the left of the boot as well, with the amp, in that
can't wait:slayer:
6" is what I read, haven't actually measured it myself as my car is in at Fiat atm...Not a biggie though, just build a false floor and raise it a few inches. I was planning on doing the same as you, building a little cubby hole in to put the pump and everything.
P
Space saver will fit though
