Does anyone know of a good high-amperage power connector to use for amp power cabling? Can't believe these things don't exist, but either I don't know what they're called to find them, or nobody has ever cared before.
Basically I want to be able to disconnect my amps easily with some kind of plug/socket arrangement.
The closest solution I've seen so far is the Vibe Fast Plug. Fair enough, except it only goes up to 8AWG, and I'm needing 4AWG.
Ideally it would be like a big insulated screw cable for each terminal, making normal AGU fuse holders a good candidate, except they've got two screw connectors and a fuse in the middle. Too complicated and messy!
Is there some kind of unfused 4AWG alternative? Something that wouldn't short out easily? :bang:
