ok so i have bravo 1.8 with alternator noise now i know that types of alternators on these cars have a habit of producing noise my brothers 146 and dads 155 did it same car electrics to a point and with the free engines very similar alternators but i figured modern sound equipment would be able to cope as my head unit was fine
ao anyway recently i have replaced everything with blaupunkt
head unit is
http://www.bluespot.co.uk/stock/queens.asp
speakers are all from there
57cm
130cm
and 5 by 7 all from th seriese
but i doubt there to blaim
and it all worked fine had absolutely no noise and sounded fantastic
i also got an active sub small one to hide in the car
http://www.bluespot.co.uk/stock/spkr0_2.asp
now this is connected to the main power in on the fuse box the other side of the dash and earthed to a bolt on the chassis all connections are soldered
now as soon as the amp comes on it seems to feed the noise from alternator back to the head unit and out all the speakers except for the sub speaker that obviously wouldn't play this high pitched wine
now if i disconnect the subs power it goes and works fine if i disconnect the rca's it goes well actually the apm turns it's self on and off with audio signal from these but for the 60 seconds that it remains on with these unplugged it's gone
if i simply touch one of the rcas earth to earth without connecting the centre pin it's back again
now the sub is wired to the head unit with
http://www.bluespot.co.uk/stock/preamp.asp
this
and
http://www.bluespot.co.uk/stock/rca.asp
this
as recomended in the instructions for both active sub and head unit
i'm going out to the car to reroute some cables and see if i can isolate the noise but i dont have much hope
any suggestions for how i can get rid of it
maybe an inline choke on the power
or i also found this
http://www.m-99.co.uk/Car_Audio/Noise_Suppressor/noise_suppressor.html
anyone think it would work in isolating the amp from the head unit or is it just worthless tat
thankyou all
edit: oh an i also noticed the noise is not affected buy altering the subs volume nor the head unit volume as such i can droun it out this may help in isolating were it's getting in you know kind of post amp in the head unit
head unit is
57cm
130cm
this
and
this
thankyou all
