Old 11-12-2008   #1
retro all the way!
jonboy739 has donated!
engine sound coming out of speakers
my system was ok until i pulled one of my audio leads out that goes from one amp to another, i needed it for my decks (thats were i rob it from in the first place for my car amp) anyway when i put it back in the car im getting engine whineing coming out of my speakers, if i play with lead a bit it goes off but travel down the road a couple of miles and it comes back, i've made sure its not near the power cable, what could it be? and yes i know about supressers but it didn't need one before, it worked fine.
TIPO SEDICIVALVOLE
I'VE GOT A BIGGER ONE THAN
YOU UNO DRIVERS!!
TRANSPORTING CARS NOW
SO KEEP ME IN MIND
jonboy739 is offline Reply With Quote Quote
Old 11-12-2008   #2
Re: engine sound coming out of speakers
Either a bad earth or you need some sort or supressor, oh you mentioned that.
Its here : Punto Evo, 1.4 Active 3dr Progressive Black
Last: Grande Punto 1.2 Active GT1
Clifford 330x1
joeraz is offline Reply With Quote Quote
Old 11-12-2008   #3
Benjammo has donated!
Blot in Hell Champion
have you run it next to the power cable? it sounds like its picking up interference off it. I'd re run the phono cables on the other side of the car, maybe look at getting a better set with shielding built in. if you write a letter, its not too late for santa to stop off at halfords
Benjammo is offline Reply With Quote Quote
Old 11-12-2008   #4
More ICE Please
volxstu's Avatar
volxstu has donated!
Just as a guess the area around the HU is metal isnt it, so perhaps when you re put in the RCA it is sitting closer on that metal than before.
Check all earths and make sure that you are earthing to one point rubbed down in the spare wheel bay sometimes it even does good to earth the HU to this point also.
I have never used suppressors so i dont even know of they work i will try and find out.
Car Audio Goodness at its best for sale.
http://www.fiatforum.com/classifieds...?product=28141
volxstu is offline Reply With Quote Quote
Old 11-12-2008   #5
Mk2 Sporting Punto Baby!!
Ash1711's Avatar
Ash1711 has donated!
Quote Originally Posted by Benjammo View Post
i agree with Benjammo.
1.2 16v X reg Mk2 Sporting Punto
Ash1711 is offline Reply With Quote Quote
Old 11-12-2008   #6
retro all the way!
its only a short lead, that goes out of the output on one amp and into the amp next to it, the amps are screwed to the back seats and i've run the phono lead over the top of the amp and the power leads run under the amp so there not near each other, i'll check all connects again and make sure nun are lose.
o and santa is feeling the credit crunch and missing are house out lol.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 11-12-2008   #7
retro all the way!
Quote Originally Posted by volxstu View Post
HU as in head unit? if so its all plastic, if i hold the phono lead near the amp it goes off, which i would put down to bad earth but earth seems ok, the only other thing i can think that it might be has the phono lead is had it.
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 11-12-2008   #8
If its a bridging lead, I'd be tempted to say they may have seen better days and maybe time to replace them. I thought you were on about the ones from the headunit to the amp.they shouldn't be too much for a short set of shielded phono's.
Old 11-12-2008   #9
what about http://www.maplin.co.uk/Module.aspx?ModuleNo=220203 they maybe a little expensive but they seem to have a good review.
Old 11-12-2008   #10
retro all the way!
might just have to have a pop into maplins in wakey and get myself some of them, i've got 2 phono leads running from my head unit to 2 of my 3 amps and then one is linked over to the third one but they are all cheap leads, think i paid 5 each for the two 5 metre ones and about 2.50 for the short one, thought i was saving some money when i got them but it will cost me in the long run
TIPO SEDICIVALVOLE
YOU UNO DRIVERS!!
SO KEEP ME IN MIND
Old 11-12-2008   #11
More ICE Please
volxstu's Avatar
Quote Originally Posted by jonboy739 View Post
Buy decent ones then do you know what specs the output of home audio line are ie Ohms volts i bet it is different to a car so using the thin non rubbery wires could cause preblems so get some car ones.
Old 12-12-2008   #12
Home / Car, doesn't matter. No real difference apart from car ones are sometimes better shielded against interference
Moire black 5dr Stilo 1.9JTD [FONT=Arial]17 inch multispokes and a skyroof[/FONT]
kris lee is offline Reply With Quote Quote
Old 13-12-2008   #13
More ICE Please
volxstu's Avatar
Quote Originally Posted by kris lee View Post
Arent the Home ones shielded different due to the current.
(G) Strange sound coming from the motor compartment camp0s Panda (Classic) 11 21-11-2008 20:48
(T) Dreaded injector light with no whirring sound coming from the Fuel Pump chuckleberryfinn Cinquecento / Seicento 4 30-10-2008 09:14
whinning coming from speakers as accelerate psedg I.C.E 3 08-07-2008 15:58
(G) weird sound coming from the cooling system's fan? pandalovah Panda 1 19-05-2007 19:21
(T) Horrible squeaking sound coming from front shocks d_vargas Marea 2 02-07-2003 01:10
